93 40 HP VRO - Overheat Alarm w/ Great Water Flow
Josey Wales
I'm getting a steady buzzer from my 93' Evinrude VRO 40 Horse. I'm told this is the overheat alarm and must be the water pump. I've watched the water flow out of this engine real close over the last 5 years and it's still the same as it's always been...a nice strong stream from idle to full throttle.
The boat runs for about 3 minutes...then I get the buzzer. Constant buzzer until key is turned off. I was thinking I would disco the VRO (just in case it's an oil related problem - been meaning to disco it anyway), run 50/1 in the tank, and swap out the alarm sensors with new ones and then try it?
Or am I wasting my time ...should I just go straight for the pump regardless of the nice cool stream of water it's blasting out at all RPM's? I always thought a bad/going bad water pump meant less water coming out?
Tnx, JW
D
DJ
Guest
Re: 93 40 HP VRO - Overheat Alarm w/ Great Water Flow
If you have not serviced the water pump (impeller) in five years, you are about three years overdue.
When is the last time you emptied the oil tank and cleaned it? If never, there's your problem.
rattlin
Tnx, JW
I sometimes wonder if a the tell-tale stream is a good idea on these engines due to the confusion it causes. It MIGHT be the water pump, but it might be the thermostat(s) is/are stuck. Might be crud clogging up the water passages around the cylinders.
A good strong stream tells you the water pump appears to be working. That's it, nothing more. Lack of water from the tell-tale doesn't definitively mean you have a bad pump.
How hot are the heads when the alarm sounds? Can you (very carefully) touch them for long? An IR gun to read temperature would be better.
Josey Wales
Thanks for the replys!
I'm getting the steady buzzer...which I believe is the overheat alarm. Not an on/off buzzer which I believe would be the alert for not getting oil.
I was told if I had a bad thermostat that the engine would run cold, not hot. So I ruled that out.
If I had a dirty oil tank with clogged screen or water in it and oil wasn't getting to the motor would I not be getting the beeping on/off buzzer vs the overheat buzzer?
How can an engine be overheating while at the same time be peeing out a super strong stream of cool water? That's what I don't understand here. If there was say a chunk of impeller partially blocking the water route, causing the engine to overheat would I not see less water coming out and the water coming out would be at least warm from the overheating engine?
This is what was leading me towards suspecting the overheat alarm is faulty. Is there an easy way for a guy to test the overheat alarms? Can they become overly sensitive with age?
rattlin
Steady buzzer is overheat condition. If you shut engine off immediately, then turn key back on without starting, buzzer should still sound constantly and will continue until engine cools back down. Buzzer sounds at approx 200 degrees.
Themostats can freeze up in a closed position as well and therefore never open, thus restricting water flow. This is more common in a motor that's been sitting for a while. The thermosats are the last component in the water circulation path prior to water entering the exhaust stream.
There are two oil alarms... One indicates oil tank is low. Other indicates that the VRO pump is not moving back and forth in harmony with the engine crank turning. (Crankcase pressure drives the pump). Neither tells you it's not pumping oil. In other words, both alarms could be silent because neither abnormal condition is happening, but a flow restriction could still be preventing oil from flowing. Lack of oil on pistons = overheat. Use a portable tank with some pre-mix 50:1 to help rule this out.
Usually the water from the tell-tale should be warmer (but not necessarily too hot to touch) during overheat, but the tell-tale outlet is further upstream in the water path and before other possible restrictions. Again, good stream only indicates water pump is likely doing its job.
Sensor could be faulty. When it triggers an alarm, check the temp on the heads yourself. Either carefully by touch or better with an IR gun.
My guess is thermostat. Look for approx 1" hose that exits the head and goes to thermostat housing. Take loose from thermostat housing and use a larger hose (old radiator, etc) and deflect flow to outside the pan and thereby bypass thermostat. Don't run it too long like this since you're no longer spraying water into the exhaust gas stream. If the heads stay cool, aprox 100 degrees (on hose at idle), you've found your problem.
