Ok went thru the carbs, all passages cleaned, nothing really dirty or passages clogged. Ran a wire thru all passages and pickup tube. Used carb cleaner and compressed air and all is clear.
I siphon all the gas out of the fuel tank (15 gallons), quite a bit (~quart) of water in there.
. I pulled the tank and verified the pickup tube was free of debris, Think this maybe my issue. Dried it out.
Had 1 other question before installing everything. On the front of each carb is a screw plug with a fiber washer that covers the jet. All of these were a 1/4 turn loose. Should these not be tight?
Wrote down all settings for each idle screw before disasembly. Currently set them all 1 1/2 turn off seat.
Performed a compression test and have, 110, 105, 105. Used a spark tester and it is blue in each coil/plug wire.
Thanks for all the direction.:clap2:
