Re: '93 60hp Rebuild Questions
Kinda a tough call.heres why.I worked for a so called rebuild shop once .I've been told to reuse rod bearings unless the engine had obvious signs of alot of use.Or if the rod or crank was bad,rust etc.But if the eng.came apart with no real failure,we reused center mainsand top mains on the crank.Bottom crank bering was usually changed because of location of bottom end close to waterline.Also changed the bottom seal.Often the pistons were put back in their same cylWITH SAME RINGS,again unless there was obvious failure.This shop worked on low budget for all including customer.As in your case,your top cyl.had failure.So we would bore and fix that cyl.Of course,if a customer wanted all new.then we bored to next oversize ,new piston kits,new berings all through.Will your eng run OK .re-using what was already in there.Probably.I would like to hear the opinions of others regarding NEW RINGS in unbored holes.Again.The out of round hole (possibly,honing dont straiten holes,only polishes )with new round rings,It could actually hurt you,loss of compression .But.Eng was ovbviously rebuilt.WHY??Bottom 2 prior,now the top.I would dfinatly be sure carbs were ok and Timing.If the engine has minimal hours,new rings on the bottom may not be an issue.If it was me.I'd do all 3 bored,with new piston kits,new bottom main bering,bottom main seal always,new rod berings ,new rod bolts,disassemble carbs,if carbs have any issues ,new kits in carbs.change impeller and gear oil,.you can then know its rebuilt throughout.
