93 60HP - under powered and not reving up all the way
twr7cx
Re: 93 60HP - under powered and not reving up all the way
almost but not the same. This manual cover the 60hp serial 0D07.... and up, wich are thoses starting mid-year 1993 when the made the change from two carbs to three.
He need the manual covering the models just before this design change...
This is true. Mine is a twin carb model prior to 0D07.
Any idea what the password is for that RAR file?
saumon
the password is ?ribforum?. It could give you a general idea but, as said, it's not for the same model than yours
achris
More fish than mountain goat
That manual covers all 3 cylinder engines (small displacement) from 1991 to 1996. Using serial numbers it covers 0D000750 and up.
It would be helpful if we had twr7cx's engine serial number.... Any chance?
Chris.......
saumon
I cheat a bit looking on another of his oldest post and saw that his serial number is OC161680.
And i'm pretty sure the link you provided cover only mid 1993 and up three carbs design (0D00750... and up)
achris
Quite right about that manual not covering his engine... It doesn't.... but that's because his engine is 1989, not 1993....
0D000750 was the starting serial number for 1991.
Chris........
saumon
You were right! I never tought of checking if the year of his engine was ok...
twr7cx
Wow. So it's older than I thought then. I came to the conclusion of 1993, based on some websites I found quiet a while ago.
Both the Clymer and Seloc manuals that I have cover only from 1990 yet cover my engine.
achris
Tells you how good they are, doesn't it... That's why you'll find almost nobody here will recommend using them....
twr7cx
So any idea where I can find the part numbers for the correct genuine OEM Mercury manuals? The Mercury Publications website doesn't give any details - https://appcenter.mercurymarine.com/litreq/ .
twr7cx
The part number for the manual you're after is 90-86135--5.
Chris.......
Thanks, got one coming from eBay for $30.00ish USD.
