93 Bayliner 1800 Capri Outboard Restoration Project
rickryder
Re: 93 Bayliner 1800 Capri Outboard Restoration Project
Ya sure was a lot of joints being talked about :D
BTW if you want to get rid of the itch.....ya need one of them tin boats with them reevits......:eek:
93bayliner1800
Curious about opinions on bedding in stringers. I plan to bed in a couple spots...kinda like tack welding. This will make them stay in place while I walk around in boat to finish bedding. Figure I will bed in 6 to 8" sections 2 or 3 of them....that should hold them steady.
rickryder
I was looking at the pic of the stringer layout... Were there 2 more stringers closer to the gunwales? Seems like a long span from the outer 2 to the gunwale.
When I set my stringers I ran full tabs down one side of each stringer,let them kick off....then PB in a gallon ziploc bag....cut the tip off the bag and piped the pb under the stringers and pressed in with a spoon to fillet them.... I see your gonna have a tight spot between the ski locker stringers and the outer 2....
93,
I don't know if this will help or not... I'm just starting a 95 17ft capri project. Here is the bow portion of my boat without much ripped out. Mine had a live well in the bow section. I don't know if yours did or not. Either way, you might be able to get an idea of where the stringers go.
Hope this helps! Great job on your boat. I'm going to be referring to your posts a lot in my project.
93bayliner1800
Rick...that is the way it was setup from the factory...so i was just putting it back that way. And it also had a 1/2" deck. I am probably going back with 5/8, but maybe 3/4. I am not worried about weight, but more so deck height. my stringer height is almost a 1/4" higher right now as I forgot to add for lifting stringers off the deck. do you think 1/2" higher deck height would make a big difference? and I agree the inner stringers are going to be fun! lol
Good news...I stopped and grabbed a 6 pack of voted best beer in 1892...so I am ready to start bedding in the stringers this eve.
jbcurt00
You might check where that extra height puts the bottom (backside) edge of your deck as it reaches the hull sides. It is often at or very near a chine & some additional support/structure or body line in the hull, and extra height may cause the deck to land on a less supportive area of the hull.
It isn't too late to take the 1/4" off the top, or even 3/8" (if you plan to use 5/8" decking) or 1/2" (3/4" decking)
I could be wrong, so just IMHO...
So far all else seems to be going great
Enjoy the frosty adult libation!
rickryder
JB is spot on ^^ I would have the deck lay where it was..... It should rest on the chine...if it's higher there is no support under it....you can't screw the outside edge so we bed that in PB and tab to the gunwale.
93bayliner1800
Ok....I forget...what is the Chine again?
jbcurt00
I tried to find a pix of your hull, but alas, video..... But that should be enough detail....
93bayliner1800
Ok...the only place it touched the Chine was towards front for about 45 inches....then as it goes back it rises above it gradually all the way back. This was the setup factory. And there was no support under the deck at the chine other than the bulkheads. I am considering bedding strips length wise on the Chine to support deck....will take a video tomorrow to show exactly what I mean. Will get everyone's thoughts then.
Oh and it takes a lot of P.B. to bed the stringers! I have used a gallon and probably a 1/4 of the way done!
rickryder
Yes you will go through a bunch of PB....be sure to fillet the sides of the stringers and bulks with a spoon to make a nice cove so your glass will be easier to bend up the stringer ;)
Should look something like this.
93bayliner1800
Yep...I used a large foam nap and made some pretty fillets! I took and used the foam roller dry at first to get the shape I wanted then just as it was starting to kick off I lightly dipped the foam roller into acetone and they look PURDY!!! LOL
93bayliner1800
FINALLY!!! a weekend to work on the boat! I am so excited to see how much I can get done. I have to finish tabbing transom and stringers cap them, and the top cap is ready to go back on! Then, I will finish the sides of the bulk heads..bed,tab,cap. My goal is to be ready to foam by next weekend. We will see how it goes. Will take some videos along the way!
93bayliner1800
Well have a pretty good weekend! Rained all day, but still got a good bit accomplished. I am looking to be on track to put the top cap on Thursday or Friday.
riptorn
Good job 93bayliner1800. Smart thinking on putting the Cap on before finishing up with the glassing on the floor. If your not a Chess player you should be.Lol:)
93bayliner1800
The Top Cap is ready to go back on!!!!
rickryder
Congrats on the recapping! Glad to see it went well. Your in the home stretch now ;)
GT1000000
Awesome Progress...Looks like you might just make that Independence Day Splash Date...Way To Go!
And thanks for taking the time to make the vids...they are going to be a great source of information and inspiration...
