FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have a 93 johnson 60hp with the auto oil injection I want to stop using it do I need to change the fuel pump or just block off the oil tube and disconnect the wires thanks
No need to change the fuel pump. As you said, plug the oil intake line and disconnect the oil alarm. Mix your gas in the tank 50:1.
You will need to flush out the straight gasoline from the carbs and fuel lines before starting it. Disconnect a fuel line at the carbs, pump the primer bulb until the fuel chages color.
You will need to flush out the straight gasoline from the carbs and fuel lines before starting it. Disconnect a fuel line at the carbs, pump the primer bulb until the fuel changes color.
Or mix you gas in the tank at the correct ratio while it is still hooked up. Run with double oil for a while and then do the disconnect thing. This will make certain that you get no raw unmixed fuel through. You can do this if there is no pump issue to begin with. If you are changing over because of a pump failure then the other way is the way to go.
