93 Johnson 70hp J70TLET clockwise impeller correct?
alanfox55
Hi guys please set my mind at ease. I just rebuilt the water pump and I put in the impeller while turning the drive shaft clockwise which is correct right? I've never seen or heard of a motor where the impeller rotates counter clockwise and my service manual says clockwise but I just want to make double certain it does before I start it. If you had a two motor set up would one of the motors impeller rotate counter clockwise?
I do not believe the 93 model 70 hp was available as counter rotating !------------You put the impeller on the shaft and make sure the key is driving it.--Then you lower the pump housing on while rotating the driveshaft the way the motor runs.--Nothing to it.
