saltybutwet
Thread starter- Joined
- Jun 30, 2013
- 197
1993 Chaparral 180 SL Mercruiser 3.0 with a cracked internal block, I want to swap a 1984 Mercruiser 140 engine. I purchased this boat only for the engine. It is pretty much all original, even the manifold, and risers are original. I checked the compression 148-150 on all 4
The owner, who has owned this boat for 20 years, said it started to run hot once recently, so he shut her down for a bit to let her cool off, then started her back up, then she was fine.
I decided to take a chance on the engine as a replacement for my 93 Mercruiser 3.0, of course only after I figure out what was the causes of that heating up issue, and if I figure out that, I would like to know what other parts can I transplant over to the 140, from my 93 Mercruiser 3.0. I also will want to sell some parts from this boat that I will not be using, and what should I keep
some background on what I checked out, and how the engine ran before I purchased it.
I did several visual inspections of the engine after the compression test, and didn't see any red flags, except for some loose wiring connectors, and i didn't see any oil leaks either
We then put the water to her and turned the ignition key, and she fired right up! sounded good, except for a slight miss, not that noticeable, and it maybe from the old ignition parts, or old gas, which smelled old. The boat has been setting for some time.
We let her run for about 40 minutes, I was watching the temp gauge, and she barely got above 140 the whole time. I checked the engine oil before we started her, and after we stopped running the engine, the oil looked the same, and the level didn't rise, and I didn't see any signs of water in the oil, nor did I see any steam coming out the exhaust, so i feel safe that the engine doesn't have water intrusion at this point.
I did hear a noise coming from the rear of the engine, sounded like maybe a bad gimbal bearing or bad coupler, the stern had a vibration all across it, and when pushed on the engine, the vibration got worse. the noise wasn't that noticeable at higher rpms, but the vibration was still there.
The out drive worked, but looks a little beat up, and the sea impeller seemed to be working. I did remove the drain screw from the foot, and black thick oil came out, no water
here are a few pics
here are a few pics
