93 reinell 5.0L top speed
jimmy66
top speed on my boat is 43 44 mph, im running a 15x17 prop, will i gain anything by going to a 14.5x19? also my tach doesnt work
captkevin
Re: 93 reinell 5.0L top speed
You need to fix the tach before you try & change props. Without knowing wot is you are only guessing & as a result end up damaging the motor. Once you know the rpm's then you can go from there.
jimmy66
when i turn on my blower motor, the tach either bounces all over the place or pegs! any ideas?
craze1cars
Your wiring has been corroding for over 18 years. So it likely needs work. Remove tach, clean all electrical connections, spin the big cylinder selector screw around in circles a few times to help clean a bit of internal corrosion and reset where it was, then reinstall. Usually bad grounds cause gremlins like you describe. So now go and clean ALL of your grounds on the entire boat...under the dash at the ground block, at the battery, at the engine connection for the ground cable...and as long as you're at it, might as well do the positive side too.
After all that, if tach still doesn't work, replace tach.
