Re: 93Johnson fast strike 150hp - Ingnition help needed
Thought I'd re-cap for future searchers. I replaced the power pack the other weekend and the motor has run perfectly since. I bought a package deal on line with new pack, plug wires, and optical sensor. Kit only included 4 of 6 wires (seller is sending other 2), but I just kept 2 of my old ones. Although the pack specifically called for the "gray special wires", I went to two marine shops and they told me there would be no harm in using my old ones. Also, I did not install the optical sensor. I did not think this was broken so I did not replace it. I though better to install the new power pack and verify that was the root cause. Then, if my sensor ever dies (I hear they die frequently) I have the part to replace it. So that's that, all fixed up and running great. My initial symptom was an intermittent spark. Half the time I would go to the boat ramp only to find that the engine just spun with no fire. I would pull the plugs to test and would have no spark. The boat would sit for 30 minutes and I'd try again and vuala - it fired right up. Pulled the plugs and nice strong spark. It did this sporatically for 2 years. Finaly, it started to die intermittantly while driving and that's when I new it was either stator or power pack. Tested stator statically and eveything tested good. That was enough reason for me to purchase the new pack. Hope this may help someone in the future with similar problems. Thanks for the above replies.
