94 150 Johnson Cutting out under acceleration
Fat Monkey
I have a 94 150hp Johnson that is cutting out when I try to accelerate. It does not seem like a miss it just stumbles repeatedly while I am giving it throttle. The carbs were rebuilt last October and that didn't seem to do any good. I did notice that the plugs are very oily.
Any suggestions would be appreciated.
Thanks,
Mike
AlanR
Re: 94 150 Johnson Cutting out under acceleration
Whats your compression?
Fat Monkey
I am not sure of the compression numbers. But, the shop that rebuilt my carbs said compression was in spec. and that the ignition was good.
Maybe I should check the compression myself, I have the tool.
Thanks,
Mike
reeldutch
if the carbs are rebuild and the high speed yets are all in good shape i would check out if the timing is advancing.
also fuel presure.
and always check the compresion.
