wannabfishing
- Joined
- Aug 16, 2006
- 6
So here's the deal,
A couple of weeks ago i used the boat, during idle the water from the water outlet was sputtering during idle, but a nice constant flow when running above that.
Took boat out this weekend, and no water from the pee hole during idle at all. It would pee just fine during running around, but when you stop and idle, not water just some steam.
I'm thinking the impeller was somehow damaged, not provideding enough pressure to pump water at the lower RPM's, but am not sure.
I plan on changing the water pump out, but what else should i check for?
