'94 25hp merc smokes
bktomlin
Hello,
I just purchased a used 1994 25hp merc and had it checked out, the mechanincs saying it was fine. I got it home hooked up water supply and started it up and it is smoking pretty bad. Is this normal? I know it is the correct mixture, but maybe its just old gas? How much are they supposed to smoke if any?
Brian
Re: '94 25hp merc smokes
Brian, It could have residual oil from winterizing. You really need to run it a bit to clean it out. It should leave a puff of blue smoke when you hit the throttle, and have a faint trail of smoke at cruising speed.
ifixf18s
I have a 97 mercury tracker motor. I seen where you said you know the fuel oit mixture is right, but you didnt mention what that was. My manual says 25:1 for the break in period (the first tank of fuel) and after that i should go with 50:1.
mthieme
Assuming it's broken in by now :) 50:1 is correct.
bktomlin
The mixture I am using is 50:1. I will try some new gas. Thanks
