'94 3.0L holley carb float height adjustment
tbest01
What is the float height on a 2 barrel holley carb? and how do you adjust it?
tbest01
Re: '94 3.0L holley carb float height adjustment
Have other numbers below that one, but believe that may be the one that you need. again, #3854087
skydiveD30571
Thats the Volvo part number, not the list number. Is there another set of numbers below that one?
Also, do you know your engine's model number? There's a few that could have been used during '94.
Don S
attachment.php
tbest01
have #80321-1 and #1753 Engine model # is 3.0GL D-MMDA
tbest01
Awesome! thanks much for the rapid reply! Have a good day:)
skydiveD30571
Look at Don's post. for the 80321 carb the float setting is parallel to fuel bowl when bowl is inverted. You will have to pull off the fuel bowl to adjust it. Is yours externally adjustable? aka does it have a nut around a screw on the top of the bowl near the side where the fuel line comes in? According to the part number you gave me, it is externally adjustable. If so, invert the bowl and see if the float needs raised or lowered to be parallel with the bowl floor. Adjust it using the directions in the picture.
