'94 50hp force water in lower unit
BTMJAP
Had the boat out the other day, ran great until we went to leave. It would not shift into forward gear. It would go into reverse. I drained the lower unit and there was some water that came out with the oil. What can cause this? Thanks
roscoe
Re: '94 50hp force water in lower unit
A bad seal or gasket could cause the water intrusion.
Adjusting the shift linkage would likely fix the shifting problem.
