tjtheman007
Thread starter- Joined
- Jun 5, 2017
- 27
Hey all!
Researching through the forum, and the information here is great! Love the stickies as well. Been a long time browser, but finally decided to join. I'll get to it though.
I have a 1994 Four Winns 190 Horizon. It has the Ford 302 v8 (Cobra FL) mated to a OMC Cobra SX outdrive. (Volvo Penta SX) I know my year is tricky because it is the first crossover year for the Volvo outdrive.
Problem: Yesterday, first outing of the year, after I just replaced the impeller (The one right below the alternator on the motor) I took the boat out in the Kankakee River, did great putzing around, going slow all day. About to bring it in and I decided to open up the throttle. Great for a little bit, then all the sudden something let go. Engine RPM's shot up and boat's speed over water instantly dropped. Something slipped. Backed it completely off, put it into neutral. With the engine still running, I put it back into forward gently, and no problem. Went slow. Tried to give it more throttle, as soon as the RPM's start increasing, it just lets go. Killed the engine, started it again, put it into gear, fine going slow, again try to give it some forward throttle, lets go. I then backed off and we slowly crept to the boat launch, barely in drive. (Luckily we were only a couple yards away.) I did NOT hit anything in the water.
I checked my outdrive fluid literally right before launching the boat. (Put the drive down all the way, etc.) And it smelled and looked great; no water in it, good level, great coloring, etc. (Its been a little over a hear since I have changed the fluid, but I only put maybe 40-hours on it last year, and that is pushing it.) Upon returning, with the issue, checked the fluid again, metal flakes and burnt smelling.
My local marina is backed up until the very end of June. I'm ideally needing the boat back in the water the week after the 4th of July. Becuase of the timing, I have already decided to pull this myself. I'm very mechanically inclined and I do own the ACTUAL OMC manuals (Not just the "Solec" manuals) for my exact boat. I figure I can get this tore apart and that way source and order the parts I need in hopes they'll get here in time.
I'll be diving into those manuals tonight actually to prep for the tasks ahead.
Questions:
1. So, I already know I need to pull my outdrive as I found metal flakes in the fluid. Anything else that I should checkout? Anything specifically behind the transom plate as well?
2. With pulling the outdrive and needing to rebuild it anyway, am I able to upgrade to a Volvo DP unit? (The only thing I am unsure of is my transom plate looks a tiny bit different than the "real" volvo SX drive units.)
- I am not sure If I need to find just a lower and it will work with my OMC Cobra SX upper, or if I need to source the entire unit, upper & lower, along with maybe a new transom plate. Thoughts? Advice? Critiques? ANy helpful links I need to checkout?
Here are pictures of my setup. I can get more tonight/tomorrow if need be.
Thanks all for any assistance you can lend me!! Much appreciated.
Questions:
