Rickmerrill
Thread starter- Joined
- Mar 13, 2014
- 686
Ok, I'm going to ask a question about waterproofing the cleats (attached to tops of stringers/bulkheads to take the screws that hold down the sole - those cleats). I've seen several restorers that wrapped them in CSM and screwed and PB'd them in. But, being lazy I'm wondering about two other approaches. The mfg just soaked them in resin and stapled them in (Friscopboater said he was going to just soak them in resin but I couldn't tell for sure if that's what he ended up doing). Yeah I know resin by it's self has little strength... As a step down I have a pressure treated 2x4 on top of the fuel tank to hold it down. That board has no signs of any deterioration after 20 years. Sooo, I'm wondering if I could use treated furring strips as cleats. Even if there is some sweating down below I think treated cleats should easily be able to resist that level of moisture for at least 20 years. I'm thinking of using coated decking screws to attach the cleats to the stringers and putting PB in there but if it doesn't stick (these are so thin they seem to be pretty dry) the screws will still hold them in place. So if you think it's a bad idea let me know or if you think that should work let me know that too, and why. Thanks!
