94 Force 50hp
hanahawaiian
after i been search alot alot.. and went West Marine near by my house.. and they dont have parts # in book or computer for Force 50hp 1994 Impeller????
beacsue when i start the motor and i notice no Pee water come out???.
anyone can help me out?
thanks
Chris
hanahawaiian
Re: 94 Force 50hp
it is easy to replaced it? I have skill with build Chevy engines and i build Drag racing/ Road Racing.. also i have alot tools in my shop..
Im thinkin about take off lower gear and pop water pump housing and look at impeller and get # parts on Impeller...
and going to near by Mercury or mecuriser dealership repair shop to buy New impeller and gaskets..
Also i have Force Service Manual.. :D
hanahawaiian
Re: 94 Force 50hp
thanks.. but 50hp are diffrent from 100-150hp.. but 50 is really easy.. only shift bolt on bottom and unconnected it.. and i belive so.. i gotta read book again make sure..
Banditz
Re: 94 Force 50hp
UUmm if you egine is like mine, a 1990 force 50, then you wont have a pee stream. Instead you just have two little holes in the back that kinda spurt water out, not alot at all. Will be warm water coming out. just a thought, not an expert by any means. Dunno if they cheanged or not buddy. Good luck.
hanahawaiian
Re: 94 Force 50hp
Bandzit your right..
I just pulled out and check impeller look good.. and i checked parts look good water pump housing, Impeller look like new, Impeller Water pump plate.. and i dont see any Gasket???
I put back together and firing motor and i finally got 2 holes spitting water out.. it good! and but water was leaking out by 4 bolts on lower gear.. i guess it need put gasket in water pump housing..
