huck199
- Joined
- May 31, 2015
- 24
This spring we purchased a '94 Wellcraft Excel 20' open bow runabout, It ran great on 4 or 5 outings. Last week we were running up on plane and motor cut out. It would restart and idle fine as well as run at low speeds. As soon as you throttle up and plane off it died again. I took it out of the water and replaced water pump impeller. Runs good on hose but no water from telltale. I removed engine cover and checked line to telltale for obstructions. No obstructions but I realized that the line goes from discharge fitting in base of cowel but is not hooked to anything. I am not sure where it gets connected?? I ran the motor and the block is getting water and staying cool but no water is spraying out of anywhere to show me where to hook hose from telltale. Any help would be appreciated??
