94 Johnson 115HP Recirculation hoses???
X7JAY7X
I tore apart my 1994 Johnson 115HP to rebuild, but I do not know where two recirculation hoses go. On the intake block where the carbs mount, there is a total of three little nipples, I know where the very bottom one goes(it goes to a nipple beneath the wiring block). I know the top two tie together with a "T" fitting but I dont know where the third hose coming off this "T" fitting goes. Does anyone know? Also there is another little nipple just to the left of the throttle assembly (not the one under the wiring block). I do not know where this one goes either. Can anyone help? I am thinking that these two unknown hoses are tied together but I want to make sure.
hondon
Re: 94 Johnson 115HP Recirculation hoses???
Is this a looper or a crossflow?Help us help you with some model numbers here.
X7JAY7X
yeah it is a crossflow, I really dont know much more than it is a 1994 Johnson V4 crossflow 115HP
impaler
two lines in the middle of intake tee together then goto the center main bearing, the other two go to the bypass covers on #1 & #2 cylinders.
