'94 Johnson 25HP Running VERY High at Idle
prayferrell
Cleaned the carb and been doing general tune up on motor. Started it up, and it is running full out at idle.
I noticed the arm connecting the carb to the throttle was too long forcing the carb to be open while the throttle was at idle. So I shortened the shaft, but I am still facing the same problem.
If the same arm was on before without any problem, what did I change while reinstalling the carb? If I hold the carb down then it idles fine.
Also in the process of taking the arm on and off I managed to snap one of the floating holders does anyone have a part number for that?
Thanks in advance,
-P Ferrell
