Mounted behind the transom of a 22' Boston Whaler Outrage on an extented Gil bracket. In rough water on Lake Superior the Merc 225 cuts out at lower throttle positions. To maintain headway in rough water (waves of 3-1/2' to 4' or higher) the throttle has to be at nearly it's full position to keep the engine running and the OB consistently accelerates going up a wave, decelerates or cuts out going down. Fuel tank was at least 75% full on these occasions. Merc dealer rebuilt carbs, replaced all coils, replaced throttle position sensor and tried a new computer with no effect. Fuel primer bulb didn't appear to be collapsed during surging. Water seperator filter was replaced twice and poured into a glass jar to check for water. No water was found. First incident - found some water under the engine cowling. Caulked gap in the engine cover gasket. Next time almost no water was found under the cover. The tilt of the engine affects how smooth the engine runs at idle. In smooth water the engine runs well at all throttle positions.
