bakerderek0
- Joined
- Jun 11, 2010
- 13
I recently purchased a 1994 Baja 170 Islander. It has the 94 Mercury 125 ELPTO. (2 STROKE FOUR CYLINDER CARB). I changed all four spark plugs; changed fuel filter, and put a bottle of seafoam in with a 15 gal tank of gas. It has a 13x19 prop. Acceleration is sluggish, the engine will die if I give it too much throttle. At 5000rpms (WOT), Top Speed is 30mph. Any Ideas on what I need to do? I believe this boat was sitting for awhile before I purchased it. The compression test is 135 on the top two cylinders and 140 on the bottom two cylinders. Should I take the carbs off and clean them? I'm really at a loss here, any suggestions are welcome.
