Looked through forums and didn't find anything - maybe I missed it but I just replaced impeller, upper housing, lower plate and gaskets - I'm not getting any water out the tell-tale. That's the short version.
The details:
For testing, I'm using the earmuffs in a large tupperware container. Unfortunately I don't have a container deep enough for full submersion.
Housing nuts/screw - 50 in lbs - checked and double checked - in fact this seems tight to me and the shaft is difficult to turn with this torque.
Fins are pointed the right direction in the housing - assuming clockwise rotation.
Seal is installed on the shaft and fully pressed against the top of the water pump housing.
Key is properly installed in the impeller - I felt it slide over the key during installation.
Also installed new thermostats but to test presence of water, I removed them temporarily just to see if water would pass through but to no avail.
Water tube is lined up with the water pump output port as it should be.
I tried pouring water in through the thermostat opening to see if it would run out the bottom and it does so it seems to have clear passage - yes, some comes out the tell-tale too.
To complicate matters, on this model, there is no tell-tale until the thermostats open once it get's warmed up and I'm afraid to let it run much longer that I have already - as there should have been a tell-tale already.
Any help would be much appreciated - I'm sure it's some dumb thing I missed.
The details:
