Texasmark
- Joined
- Dec 20, 2005
- 14,893
Without speed and RPM #'s I am going to assume you have engine trouble...... A 13p on a 17' boat with a 40hp & proper setup should plane out fine.....
My bother had a Tracker TX17 with a beat up 70hp evinrude running a 19p prop and it was instantly on plane. If the engine sounds loud (high rpm) when you hit the throttle your prop could have a slipping hub...
70 is almost 2x hp and in the rated hp arena for that boat. Gear box on that 70 is down around 2.33. His is 2.0 A 2.33 will turn a higher pitched prop and get the same results essentially. Now if you were running that 19 on a 2.0 gearbox then yes you have something with the prop being so much higher in pitch than his and getting stellar results in the hole. Setup has something to do with it too.
Just may be that he is experiencing normal planeout (hole shot that isn't a shot) for that boat with that engine......his comment about "a slow steady planeout".
