'94 OMC/Volvo 5.0 starting problem
Status
Not open for further replies.
samdimaio
began winterizing '94 four winns horizon 180 se with omc/volvo 5.0. wont start; turn the key, double checked that shift lever is in the neutral position, absolutely nothing happens, kill switch is engaged, no solenoid click, no sounds at all, battery is fully charged - 13V, accessories all work, trim pump works, starter turns normally only when i put a screwdiver across the starter relay - but engine will not fire. have not ran the boat since early sept. when uncovered today i noticed everything in the engine compartment was damp - let it dry out for several hours before attempting to start. this has never happened before.
any recommendations would be most appreciated. might there be a fuse or reset switch that i should check? ignition switch bad? kill switch bad.
Don S
Re: '94 OMC/Volvo 5.0 starting problem
This is the second time you have posted with repeated posts. You need to hit your refresh or reload button so you can see that you question is posted. It would also be a good idea to go back and read your old posts, and answer questions that people trying to help may ask.
Status
