'94 Sea Ray 220 Signature Select I/O Engine Hatch Strut
Trips
Hi, I am having trouble finding a replacement strut for the engine hatch cover. There are a few of them, but specifically I need the large/long one. Any advice?
Thanks
moosehead
Re: '94 Sea Ray 220 Signature Select I/O Engine Hatch Strut
A non-OEM replacement gas strut is more than satisfactory, the primary need is coming close the to same eye to eye measurement of your existing shock, and replicating the force in lbs. of the shock pressure. You can source these in many auto parts stores, and even e b a y has a few replacement gas strut vendors that are very good.
agallant80
Measure what it is closed and what it is extended and go to the auto parts store. They will have something that will fit.
Slip Away
Yep, a strut's a strut. Measure twice, buy once. Problem solved.
lkbum
Thanks
McMaster Carr, one of the better sources for things like this.
McMaster-Carr
Trips
Thanks for the input, but this part is an electric strut. They look to be pretty pricey and I'd love to go aftermarket if I can find one that is an exact fit.
moosehead
Trips, you can also replace a switched electrical strut with a gas powered unit. You'll obviously lose the auto button lift fuction, but a manual lift of a heavy engine bay lid with properly loaded gas shocks is not atypical nor difficult. A potential benefit is you can get to the engine bay if power is lost for some reason.
crabby captain john
X 2 especially if power is lost and battery access through engine compartment.
Trips
Moosehead and Crabby Cpt. Excellent points and will probably go that route.
