94 seadoo xp problem
ernie36564
i have a 94 seadoo xp. how do you bypass and which hose is the reserve on top of tank where sending unit is. can i just take and put the hoses together at fuel selector. also can i leave the oil injection working and mix the oil and gas maybe do like 30-1 or 40-1 instead of 50-1.
Jeff Walkowiak
Re: 94 seadoo xp problem
there is a mark at each nipple,, it is hard to see but it is in the plastic cap.. forget the selector go from the reserve pickup directly to the filter and then to the fuel pump on the front carb ,, block off the other hoses accept the return line back to the tank , leave the vent line alone obviously.
ernie36564
okay when you say a mark on the side of round sending unit just below the nipples. what kind of mark is it? at one of them it looks like its just a seam where they put plastic together. also what about the oil mixture. can i leave oil injection running and just mix something like 30-1
Jeff Walkowiak
it is next to each nipple on the plastic// either use pre mix or use the oil injection.
