I just finished overhauling a 95 Johnson 115 crossflow. I have a couple of minor issues to fix (plug wires, small fuel leak) but I do have one thing that is driving me nuts.
I'm leaking water at the front of the powerhead under the carbs. I can't see any leaks along the gasket so I'm not sure where its coming from. I'm going to pull the powerhead and see what I can see but is there anything beyond the obvious (improperly installed gasket, left a piece of old gasket material on the mating surface, etc) I should be looking for? All the hardware is installed and tight so I think its a probably something stupid I did but any other areas to check would be appreciated. The motor was originally a jet unit but I put a propped lower on it so I don't know if there would be any water gallery differences.
I installed a new water pump and t-stat kits while l had it apart and I'm getting good water flow out of the tell-tale.
Thanks!
Branden
Thanks!
Branden
