ebear
Thread starter- Joined
- Sep 10, 2007
- 57
.I've been through everything I can think of.
Starting, It will what I will best discribe as a backfire out the exhaust [never thru carbs] and stop the motor then turn a couple more times then do it again. I can get it to run by putting the control in full start advance and cupping my hand over one carb for a short 2 seconds while turning it over once it starts it runs but the backfire/pop is still present.Running the boat. at top end the pop is more prevelant and robs power when it happens.
Background. I picked the boat up with #4 blown.
I rebuilt the motor being careful to put everything back exactly as it was before. Now i have to stop there and add that #4 was pretty beat up. I had the block machined 30 over, got a 30 over piston and changed the rings on the other 3. The head was beat also, but after a bit of grinding and sanding, it came out pretty clean so I put it back on. I have heard of chunks getting stuck in the metal and causing detonation so I made an effort to be sure that it was clean.
I went through all the wiring, checked and reset the timing to 32 deg wot cranking. I rebuilt the carbs, floats are level, mix screws 1 1/2 turns, fuel pressure is at 3.5 lbs cranking. I indexed all cyl and it fires on all marks. What am I missing please help I wat to take it out someday.
