low oil???
you might need to pull sensor wires and find out
I have this issue as well (beep beep beep beep beep beep beep), oil well sensor has been replaced, engine smokes while running (so it's gotta be getting oil?) and pisses water just fine. The beeps' tones change to a higher pitch when revving higher, and the beeps start as soon as the motor turns over, right from cold start. I'm pretty sure it's a bad alarm module, is there anything else it could be? Would like to figure it out before I order the part. Thanks!
