Hello All - having a little problem with my 95' 175hp Evinrude. After warm up it won't take throttle with out a shot from the primer. When I start to throttle up the engine will flatten out. If I keep appling throttle it will die. If I engage the primer for a second or two the it rpms come up and I can hammer the throttle.
Starts great cold or warm. Cold and warm idle are OK but with an ocassional sputter after warm up and runs great at all rpm ranges including WOT. Tried squeezing the fuel bulb but doesn't have any effect on issue.
Local shop diagnosed this as bad Power Pack and timing base. Replaced Timing base(optical sensor) Power Pack, plugs, fuel filter and screen. Motor definately runs different for the better but stalling still an issue.
I've ran it 5 or 6 hours now since replacing parts. Plugs look pretty good, dark tan with very little carbon deposit. When I pulled plugs the plug from the top left cyclinder had quite a bit of oil on threads and plug seal. Not sure if that's normal or not but it doesn't seem to smoke excessivily when idling so I think the VRO is working OK. However, the plug from top left cyclinder did have a small amount of carbon deposit while others have none.
Also checked spark advance/throttle linkage timing and set according to manual. If it was out of sync it wasn't by much.
Also notice that carbs on top and intermidiate carbs on right bank are wet with oil/gas. Wipe excess off and it appears again after an short period of use. Not sure if this is normal or indication that bowl gaskets need replaced?
Wondering if idle air mixture is out of whack. Reading Clymers shop manual carb adjustment it says the idle air screws should be two full turns out from light seat. All six of mine are eight turns out from light seat. Is the shop manual correct or is the eight turns correct?
I've spent close to $500
trying to correct this problem so any input would be very much appreciated.
