bassturd440
Thread starter- Joined
- Sep 23, 2006
- 2
Hello fellas, I hope you could help me on this. Last night I took her out and I was having a prob with it stalling at open throtle. Pisser was fine, water stream was not hot, alarm did not sound but at times when I was trying to restart it, it was hard to start like it was seizing. When I first got it in the water I was having problems with the connection to the fuel tank being loose and could not get the ball to fill,but I don't think this is the stalling/hard to start problem (hope I am wrong) the problem did not happen until about 5 mins after wot. and it was start, floor it, stall all the way back to the dock. Most of the time that I would fire it back up it would strt easily but on occasion the starter would have a really hard time turning the motor. could this be possibly an oil injector problem? I pulled the pluggs and all looks fine, normal carbon, no steam cleaned plugs or wet with gas. I did not do a comp check, and the fuel is fine coming out of the line while pumping the ball. I also haven't checked the spark (need a second set of hands).Thanks, Joe:'(
