95 50hp no spark
cyrusperry
i am at the end of my very short rope. i have replaced two coils and still no spark can anyone tell me where to find the triger switch and how to check it. i have also traced all the grounds and cleaned them. (HELP) by the way this thing was running for about 2 weeks and after about 20 spark plugs stopped working at all even with new spark plugs could this be a tell tale sign of my problem.
roscoe
Re: 95 50hp no spark
The first thing to do is get yourself a Clymer Force repair manual, or a factory service manual.
There are very detailed troubleshooting and testing procedures in the manual.
The stator (generator) is up under the flywheel.
The trigger assembly is there also.
The switchbox is on the side of the motor.
All can be tested, and through the process of elimination, the problem can usually be pinpointed.
cyrusperry
if you were a gambiling man what would you say it was if i was getting spark but going threw spark plugs and now very little or no spark.
cyrusperry
ok i think i found my problem I traced all my wires and low and behold I found somthing. now if I only new what to call it HA HA its on the side of the motor about 2in by 2in box and its incased in a seethrough plasticas you can see from the pic nice black spot where its burnt up can anyone tell me what its called and about how much a new one would cost me. thanks
cyrusperry
thats it, i priced one today cost 213.00. one question befor i buy one would this why Im not getting spark.
cyrusperry
Ok i got a new one hooked it up and ta-da ---------------im back to having spark but it seems week, should i be able to hold the end on the spark while i turn it over and only get a little shock, I would think it should set me back on my heals.:eek: i dont no what to do next.
