95 force 75hp gear troubles!!
shrimpman123
ive got a 1995 force 75hp,and when its running wot or close to it,under a load etccc..... it jumps out of gear sort of,.Kinda sounds like its cavatation, but its not.when put in neutral and then back into fwd it does fine, but will do it again, after a while. also engine revs high when it happens and you can hear gears rattling etc... my questions is can this be adjusted,and if not can these gears be reversed,Flipped like we used to do in older johnson,with the clutch dog,fork type of shift inside the lower unit?? thanks guys for any and all help !!
wncboater
Re: 95 force 75hp gear troubles!!
Sounds very similar or maybe identical to the problem I posted about my 1996 120 hp yesterday. I'm still hoping to get more responses!
roscoe
Yes you can flip the gears.
BTW, you don't have a 1995 75 hp.
The 75 was made from 1996-1999.
