alterego_k_mercruiser
Thread starter- Joined
- Oct 22, 2024
- 11
I'm working on a '95ish glastron ssv195 with Mercruiser carbureted 4.3L. Ser num. F292586. No starter turnover issue. I can jump across starter solonoid & slave solonoid and it will spin. I see 1 purple/white (or yellow) wire near starter solonoid with a round terminal & black rubber cap. I want to verify the wire b4 i takw a chance & its not an ignition wire. I've looked online but havent found anything exact. I'm not one to assume either. Theres 2 large terminals. All reds are on positive, small terminal has 1 wire, yellow/red stripe. I've more experience with auto starters and have never seen a starter solonoid wire with a tight rubber cap on it, but i suspect this wire is why it won't turn over. Or, its for a sensor i cannot see. Any help is much appreciated. Hull number GLAM 9966a595. Engine Ser. num. F292586 Many Thanks
Reply
*note purple/wht (or yellow) wire at top of pic, with rubber cap. Thats the wire in question. Where does it go?
Reply
