jeremyeasen
Thread starter- Joined
- Jun 20, 2002
- 72
My 1995 Oceanrunner 200 would occassionally stall out while idling, but it's getting worse. I changed the plugs and its worse (same plugs QL78YC). The old plugs were not fouled. A mechanic last year installed 133 degree thermostats and this seems too cool. At cruise, I run 160 degrees per the OEM water jacket gauge, and at 800 rpms at idle its 125-130 degrees. This seems too cool. It idles fine until I get to 130 degrees, then starts stalling. Should I be using the 133 or the 143 degrees stats? Thank you.
