95 Merc 115 back firing and not starting after stator and trigger replacement
firefltmedic
I have a '95 Mercury 115 that I recently replaced the stator, trigger, voltage regulator and plugs. Reason for the placement of the stator, trigger, and voltage regulator was due to the tachometer not working and the voltage on the dash showing 10 volts at idle and 11 at full throttle.
When I was replacing the wires I only disconnected one wire at a time to make sure I didn't cross wires during this entire process.
After getting everything back together, it will fire once and then backfires.
Any ideas?
mustacheyouaquestion
Sounds like you got the timing off a bit when you reinstalled the flywheel. Are you sure that you reinstalled the flywheel properly?
firefltmedic
Turns out that when I started it afterwards, the key holding the flywheel to the crankshaft had broke. New one placed and running good now. Thank you.
Johnson110
I believe that is important that the flywheel is torque to spec or it will shear the key!
