abritton77
Thread starter- Joined
- May 10, 2010
- 18
I am going to try this again. I tried to post this earlier and guess I did something wrong because I cant find it now. If you guys see 2 post, I am sorry. I am having a problem with a boat that I recently bought. It is a 95 Ranger 461 with a jack plate. To me it seems like it never has the power it should and with 2 grown men and full livewells it wont hardly com out of the hole. It seems like it bogs when you give it throttle and I believe is missing some. It seems to run ok when it is first started until you run it a while and kill it. Then it when you try to restart it will sneeze a little and be kinda hard to start. It then seems to bog at that time when you give it throttle. Today on the way back to the ramp it started missing and bogged completely down until it came off plane. I had to idle back with it missing pretty bad. I thought it had blown up but when I got it home it fired right up and idled good until I killed it. I checked the compression and all cylinders were above 120. All plugs were also firing. I replaced the plugs a couple days ago and it didn't make a difference. I have also checked the timing according to the manual and it looks as it should, but I have not confirmed that the detonation control module is allowing it to completely advance. One thing that I just found out is that maybe I dont have the right plugs. It had ngk-bu8h and thats what I put back in it. I just saw a website that the 200 XRI should have ngk-buz8h. From what I can tell the buz8h will not cause interference. I am wondering if it may be somthing like the stator heating up and not working properly. I talked to a local mechaninc and he said he didnt want to mess with it and that he thought if it were a fuel issue it should have blown up by now. I have lots of experience on cardurated v-8s but am new to 2 strokes. I also am an electrician by trade and know how to use a meter. I have also done allot of searching on here but never see a post where sombody has said that there problem is solved. any help would be appreciated and if I fix it I will post back.
