95 Mercury 40hp elpt crank but no start.
justjake843
So I've come into ownership of this merc outboard and I'm having trouble getting it running. I've got it to run for maybe a second or two but it then dies and won't start again.
I notice that fuel is leaking pretty bad around the fuel bowl area on the lower carb as well as from the little screw with the spring behind the fuel bowl. I suspect the carb needs to be taken apart and rebuilt , but I'm not too sure and I'd like input from you guys.
1995 Mercury ELPT 40HP 4cyl 2 stroke
Honorary Supreme Mariner
First thing I would do is a compression test.----Post the numbers here.----Then check for strong spark on each lead.----If those are good then clean carburetors.----Make sure you have a good battery and starter motor.----Install a new water pump impeller before launching the boat.
