boat is as stated in title. i just acquired it. the trim tab anode had the rudder thingy broken off. i didnt figure that was hurting anything, but decided to replace it while i was rebuilding tilt/trim cylinder. it came out pretty easily, but when i went to put the bolt back in the hole it came out of(just to store it till the new anode came in) it seems like the threads are stripped. not on the bolt, but on the inside of the hole. it doesnt seem like it will hold under any force if the anode is there with the fin on it. can i re-tap this to a bigger size bolt? any suggestions?
thanks
tim
thanks
tim
