95 seadooxp with some issues
Yort29
I took my 95xp 717 out on the lake today. I got on and it ran perfect, i rode around maybe 20 minutes and when i let out the throttle and slowed down it died. So i started it back up and it sounded like it was bogging, it had no throttle response and i just putted around. if i worked the throttle it did eventually go. Once i got the rpm up it it ran perfect. But every time i slowed it to idle it would bog down and wouldn't accelerate. Then i had trouble starting it up, i tried and tried until i eventually gave up and pulled it out of the water. Once trailered i went to see if it would start and it fired right up twice in a row with no problems. Anyone have any idea what is going on with my ski?
(it has all new electrical system, and a new needle & seats, also the carbs have just been cleaned, also just had a rebuilt kit put on for the fuel pump)
z284u2try
Re: 95 seadooxp with some issues
fuel pump? The acccelerator pump in the mag side carb I guess this is what you are talking about.
changed the fuel selector and grey tempo fuel lines yet? Those lines are known to break down. You did clean the mini fuel screens in the carbs correct?
