95 suzuki DT6 will not idle
discord
Hello,
I have a Suzuki DT-6, 2 stroke, however it will not idle. I can get it to run with the choke and the throttle turned to the midpoint, but not without.
I'm ready to purchase the repair manual, does anybody have any suggestions on what I should check out? Carb appears to be pretty clean. Below is a link to the clymer repair manual? Does anybody own the manual? Is it any good? The one to buy?
http://www.keenzo.com/showproduct.asp?M=_9780892877515&ID=3266989
deejaycee_2000
Re: 95 suzuki DT6 will not idle
The carb might appear clean but it needs a good clean, soak in carb cleaner overnight and blow out with compressed air .... adjust the air/fuel mixture to 1&1/2 turns outwards from soft stop .....
