korygrandy
Thread starter- Joined
- Apr 14, 2010
- 698
So I've been having intermittent heater issues since I bought the truck last spring. Finally the heater made a nice dieing noise and then I smelled burnt wires. No more heater. Then the same day I notice a quick flash of a light in the upper left of the dash. I thought it said check breaks but it says Check Gauges, while simultaneously the oil pressure gauge will be sitting at 0, and then with a stomp of the gas gets back to normal. Each time I come to a stop and get going the oil gauge will drop to 0 and bounce back to normal pressure as I accelerate.
Then when I went into the car wash the wipers started going on there own. They stopped for a bit and then started going again in intermittent fashion. I reemed on the wiper lever and it seemed to fis the issue.
Does anyone know if these 3 issues just a coincidence or are these symptoms all due to the same problem and what this problem may be?
