95 Tahoe fan selector.
scrit9mm
The fan selector on my Tahoe works on the first three settings but the max setting makes the blower stop. Any ideas, perhaps its the control panel.
rockyrude
Re: 95 Tahoe fan selector.
There is a relay on top of the heater duct rear of the resistor pack that controls the max speed. They are known to go bad.
dolluper
It's easier to get to if you remove the glove box...your 25 amp fuse was checked?.. wiring diagram below
scrit9mm
I cannot read the words on the diagram. Would this be in a haynes manual?
rockyrude
In the Haynes manual on page 12-29 is the diagram you want.
dolluper
OFF click -{ right side click{.......save as.....after saved my Doc"s ...Open then use MICRO editor to expand size + or minus bottom of editor
