96 150 water pump problem
kyle3377
i replaced water pump on 96 mercury 150 now it will not spit out water any sugestions to fix my problem
CharlieB
Re: 96 150 water pump problem
Two common errors possible during reassembly
Impeller key displaced and the impeller is not turning
Water transfer tube not plugged into the water pump
Some years the water p tube does not flow until the t-stat opens.
Before pulling the LU off and checking the pump, try removing the t-stat and starting the motor (on the hose of course) 30 seconds should show if there is water flow or not.
kyle3377
ok thanks ill give it a try if neither works wat would be the next step to correctin the problem
