96 40hp need ignition switch
buzzman
choke switch is bad which it separate from ignition ,the ignition switch is sprung and keeps starter in gauged. all i can find is magnito type need battery type w/choke built in. anyone got one or know where to get one
Laddies
Banned
Re: 96 40hp need ignition switch
For ADI or CDM ign. thats the type of switch you need it grounds off just like a magneto
buzzman
thanks for info but how can i tell which i have.?
have a new switch hooked it up engine turns over but does not start
this way hooked up on switch
letters on switch
S STARTER 2-M MAGNITO I IGNITION A BATTERY C CHOKE
yellow wire off safety going to starter
orange wire going to ingnition box
red wire battery
black wires going to M on switch
white going to other M on switch
gray wire going to choke please help
buzzman
please read reply above and answer please
Laddies
Banned
Red is B
Yellow is S
Black is one M
Orange is other M
Gray is C
I think the post marked I is a post for 12 volt switched power like dash instruments,power trim and etc.
buzzman
thanks for the info will try
work second shift sorry did not get back sooner
buzzman
where should i put the white wires
in the book all they do is go to the boat harness the don,t go to the engine harness
buzzman
on this ignition switch there is [ A] terminal for accessery
A- accessery
B -battery
C- choke
I- ignition
M- magneto
M- magneto
S- start
you say try this way below can i put white wires on Accessery
red =battery
yellow= start
black= magneto
orange= magneto
gray= choke
