Baylinerchuck
- Joined
- Jul 29, 2016
- 2,739
I’m guessing regular paint will eventually peel off due to the aluminum. It’ll need to be etched with a zinc chromate primer first.
I was actually wondering that... I wasn't positive if it was a zinc or aluminum diecast. I've dealt with both at work quite a bit and to me it DOES look to be aluminum, however many carburetors were made from both. Either way, I gave the carb a good sanding/wire brushing, and then coated it with a high zinc etching primer before the black enamel. Hoping it gives it at least SOME longevity. We'll see though.
Just for my own edification, what is the downside of the carb potentially retaining heat? Assuming its very minimal from the paint. The entire internal surface of the carburetor is still bare metal, and this surface is getting constant airflow through it as the engine sucks air. The heat transfer value is substantially higher through convection versus the conduction and radiation the outside of the carb would see. (Think heating up a piece of metal and then putting one down on the counter to cool and taking one and shooting compressed air at it... which one is gonna cool faster)
I guess in theory it would take an experiment to find out, but I would be willing to bet carburetor is losing heat through internal airflow at a much higher rate than it is gaining heat through the intake manifold which is thermally broken from it through the gasket anyways.
Dunno.. again, id prefer to limit the corrosion versus potentially run a carburetor a few degrees warmer. I'm just pre-heating the gas LOL![]()
im going to be at that point soon since im upgrading to a v8 from the 4 cylFinished up the video on measuring, making, and installing the engine mounts. Everything went really well, and feels good to have "done"... Calling it done with quotation marks, because I still want to go back and grind a couple bubbles out and maybe add one or two more pieces of 1708. I stopped where I did because I was afraid the glass was getting so thick the heat would get out of control. Should be another 30 minutes and then complete tho.
Enjoy!
I hear ya about motivation. Technically, we don't have a "boating season" around here. It's never really that cold, and when it is - its not for very long. You'll see boats out fishing all year long. Watersports not so much, but fishing for sure. I still can't seem to get my motivation up. I blame the heat.
(edit) We only have 3 seasons in Alabama....
Summer
Football
Deer
I'm starting to get a little sick of your "extended" football season lol.. give someone else a chance!
