AShipShow
- Joined
- Jul 8, 2016
- 1,803
Sorry guys, i've been radio silence for a while... just didn't realize how long it had been! Good lord, had to go to page 4 to find myself!
Just cuz I been quiet doesn't mean I've been doing nothing.. got some good news to report and some bad news... Good news is, the interior is pretty much entirely done minus a few little hear and there things and one back rest still needs upholstered... I also got some pimpery going with some color changing LED strips under the gunnels and in the engine compartment... Trailer is pretty much good to go with the exception of some brake work.
When I bought the boat, the previous owner had disconnected the brake line from the surge coupler because he said he would apply the brakes and they wouldn't release so that was his fix... Anywho, just getting around to it now, the master cylinder was NAYSTEE... It had like some form of corrosion/solidified brake fluid stuff going on... I entirely tore apart the master cylinder to pieces. It was surprisingly in good shape inside after removing all the junk/crap from it. Theres a little orifice at the exit of the master cylinder where the brake line plugs in and it was plugged solid... Thinking thats why the brakes were locking up on him... Gunk was probably acting like a check valve.
Anywho, it seems to be working great now! I rehoned the bore and bench bled the assembly when it was back together and it seems to be fine. Next, I think I'm going to run all new hard metal lines for the brakes because if the inside of the master cylinder looked like that, I can only assume the metal brake lines look about the same and I don't want to risk gunk getting back into the fluid. Start with a clean slate...
Now the bad news... I had fired up the motor on muffs a few weeks ago to just verify it still worked basically... Everything seemed to be working great minus needing a few tweaks to the idle speed, choke, and idle mixture screw... It then sat for about a week and a half and I decided to fire it up again a few days ago to check a few other things and wouldn't start for the life of me... i went thru the basics and determined I wasn't getting spark. I then went thru the mercruiser thunderbolt ignition troubleshooting flowchart and ended up being a bad ignition module... So I figured, oh well, its old, lets go get a new one of thoooooHOOOOOOOLY CRAP, $600?!?!?! Mercruiser, are you on crack?!
After some ebaying and other googling I found some used modules, but that made me a little nervous...
Then I posted over on the merc forum and was told about some Delco EST ignition... So after a little research decided thats the way to go.. So I ordered a new EST ignition system which comes with a new distributor/module/coil/plug wires/and harness.... Its almost plug and play minus splicing a couple wires together... The other nice thing is, the replacement ignition modules are like 40 bucks instead of an arm and a leg...
So thats where I am at... she successfully floated a couple days ago with no leaks in the bilge which is awesome.. so once i get the new ignition this week hopefully I can get her running again and take it down to the launch and start her up at the dock and do some final engine tweaking... After that, its gonna be time for a maiden voyage!
Thats all lol
Thats all lol
