I've got a 96' force 120 outboard and just changed out the trigger. Upon installing the new one, I figured the timing had to be readjusted since the trigger was removed and reinstalled. I don't have the manual but I used the timing marks on the top of the engine and the lines on the flywheel as a reference. I used an automotive timing light on wire #1 and noticed that the timing was set perfectly at TDC (0 degrees) when I had the engine idle with the muffs on it. I seen some posts where they set it at WOT but I can't unless I lake it to the lake. I'm trying to set everything before I go out on my next trip. Can anyone let me know if it is set correctly or how I can do it if it needs readjusted?
